Rear Spacers AND Trim Packer??
GX4SEVEND
I'm currently running the 891's in the rear with the 10mm trim packer but want just a tad more lift to even things out when loaded down so I was thinking of adding a 1" cornfed spacer. Has anyone done this? Is it safe?
Im in the same spot. The OME spacers hold up well. I think the cornfed spacers are aluminum, right? I don't see an issue. I know that stev, Sonoran steel, talks about this same topic.
I'll probably go to a taller spring. There is rumor that ToyTec is working on a 4" tall, 220# coil.
The LC coils will give more lift and flex great but don't handle as much weight.
If I was going to use a bigger spacer I would remove the OME one.
You can stack two 10mm OME trim packers to get 20mm as another option too. I put in one set of 10mms when I put my rear bumper on and that raised it back up to where it was before. If it sags over time, I will just get another set. I have also thought about getting LC coils, but with an extra ~450 lbs. back there, the 891s do great and ride wonderfully.
