Rear Spoiler -05
LukeSKY
I just relizied my new limited didn't come with a rear-spolier !@#!?????
I looked on the website, they had two options...anyone have any idea which one to pick?
1-Rear Aerodynamic Spoiler - $399
2-Rr Spoiler w/Center High Mounted Stop Lamp -$200
I think the read spoiler should be STANDARD EQUIPMENT! err
The spoiler is not standard equipment on a Limited or on any 4Runner. However, in many regions, Limiteds come equipped with the spoiler, but you still have to pay for it. For example, in the NY/NJ region, the Sports and Limiteds usually come with the spoilers from the factory, but still listed as an option. I think the aerodynamic spoiler is the new design of spoilers on the 2005's. The standard spoiler is the one on the 2003 and 2004 models. If you want a picture of both, just tell me.
cdoyle said:
could you post a pic of the new spoiler?
I've been curious to what it looks like
Here is the picture of the new spoiler. I guess this would be considered the aerodynamic one!
LukeSKY, if you get a 4rnr w/out a spoiler, and decide later to add one, you may be adding a 4th brake light to your vehicle.
Just wanted to let you know that some people might see that as a sore thumb.
the brake light on the hatch can easily be disconnected if you add a new spoiler. and the spoiler hides it from view pretty well also, so it shouldn't be a problem.
I know some people were not able to install a spoiler if it was not factory fitted. Apparently the hatch of the ones with spoilers are strengthened. SO if you can change the order do so now, or else you might have to swap the whole hatch.
LukeSKY said:
Thanks, do you have a photo of the other version like that one? Just got a 05 from 00....
Here is a picture of the spoiler on my 2003. The only difference between the 05 and 03 is the little hump on top. The spoiler on my 2003 was from the factory. The aftermarket spoilers have the brake light in a different location.
spoiler functionability
do you find rear spoiler is effective during mid winter sloppy highways, controlling airflow to increase visiblity?
Re: spoiler functionability
I find that it does, but it makes the tailgate a dirty, sloppy mess.
I would love to know the reasoning behind the spoiler change..... I wonder if Toyota has any functional reason for putting that hump on top of the spoiler.
Hitman, I don't know if it is my imagination but the ride in the 2005 with that spoiler seems a lot quieter than mine. The crossbars on both are in the same position too. I don't like the looks of it though because that hump just looks out of place.
It also seems like the rear wipers works better with out the spolier.....maybe i am wrong....00 w/spoiler vs 05 with out....
you are comparing two different trucks. i don't see how the addition of a spoiler would cause the wiper to work differently.
The Spoiler would knock the wind down to the washer blade and thus it wouldn't stick onto the window good, thus leaving water on the window...
"Spoilers...........
This device spoils the airflow over the top half of the car at the trailing edge of the car's upper surface. The spoiler can keep airflow from tumbling and creating a swirling vortex behind the car. This is important for a couple of reasons — without a spoiler, swirling air behind the car can create both
Drag (which can keep the car from moving forward as quickly as possible). Drag is expressed as a numeric coefficient of wind resistance.
Lift (which reduces the car's grip on the road at speed)"
I believe the spoiler has an opposite effect. My window remains cleaner and my wiper works without complaint with a spoiler.
Hmm... the new spoiler looks like it might do a better job of directing airflow (catching more air) and keeping the rear window a bit cleaner.
