rear springs/ shocks
Beagle(4)Runner
I have a 99 T4R SR5 w/18800 miles. Last year I replaced the rear shocks with Monroe Sensa-trac. I now feel I need to replace the rear coils but I want to keep the stock ride height. I am looking at Moog coils but they say they will work for 96-2002 T4Rs. I know the 99 had taller stock coils. Will these provide the same ride height that my T4R originally had. Very minimal off road driving. I have searched the threads for info, without any luck.
why are you wanting to replace the coils? the only reason you should be replacing is if you are saggign in the rear or just want to lift it. The shock is where ur ride comfort is at.
if u want new springs. i'd say just check the classifieds on here. plenty of ppl selling there rear springs
It seems to be sagging, more so on the drivers side. When measured from ground to top of wheel well, 1" difference between driver side and passenger. Also, recently started to feel like it is hitting rubber stops on axle when I hit a bump. No sign that the shocks have went bad (no oil leaks).
Here you go:
99 spring part numbers:
Front Passenger Side Springs - Blue / Yellow (48131-35400)
Front Driver Side Springs - Blue / Pink (48131 - 35350)
Both Rear Springs - Yellow / Red (48231 - 35210)
Here's a link to the rears:
48231 - 35210
They're more expensive than the moogs but they're oem.
How do you like the monroes? I just got a set of 99' from Ryanmaksuda (Thanks bro!), for my 01' and I want to swap out the shocks/struts when put in the 99's. I've heard the monroes are a bit of a softer ride, whats your take.
Beagle, where in PA are you? I have a set of 99 tall coils sitting in my basement. I'm just outside of Philadelphia in Glenside.
