rear springs upgrade help !!!
Marco3197
hows it going guys i have a 98 toyota 4runner 4x4 i recently had my local toyota dealer install new rear springs still seems to sag a bit i recently
installed 4 new kyb high performace heavy duty shocls i towed my 24 ft
car trailer this week and the rear sagged big time , ive read alot of doing the lc coils or 99 coils or ome what would u guys recomend for a stiffer rear
spring or is there a rear air bag set up i can do ? any help would be greattly
appreciated thanks
The LC's are a good cheap option, but they will probably sag the most under load. The OME's are a stiffer spring that will be better, but you will sacrifice a little stiffness for them. You could do the tall 99 springs with an airbag system. That should give you a little bit of everything.
What's your budget? That's the first step.
thank u for your reply .... no budget really not rying to invest 1,000s but if u can lead me in the right dirrection , greattky appreciated
Well, the 99 talls and maybe some airbags would be the way to go if you don't want to buy new rear shocks. If you lift the rear too much, then you're going to need longer rear shocks.
2001ATL
