Rear springs
hamsey
Checking to see if I need to change out the rear springs on my 2024 Limited. Installing Fox TRD Pro coilovers and shocks. There are different part numbers for the rear springs for limited & TRD Sport vs other trims. Limited 48231-35370 others 48231-35340. Can't figure out if this makes a difference. From old posts it looks like the limited is thicker and shorter but these are from 2018. Not looking to lift the rear and was told that the only difference between the TRD Pro vs limited is a 1" front lift on the TRD Pro. Fox TRD pro has to the best of my knowledge 1" more of travel according to Toyota. So not sure if these also need to be replaced. Any help would be appreciated.
Thanks, Norm
2001ATL
