Rear window acting really funny.
Not comical, just 'funny'.... sorry for the repost from the other catagory, but I thought maybe I posted in the wrong place & I might get more help here:
http://www.toyota-4runner.org/problems-warranty-issues/62496-help-05-rear-window-has-mind-its-own.html#post522628
Not sure if you saw my other post, but definitely check the switch. The more I think about it, the more it makes sense that the switch can be causing your problems. It's the best place to start, if nothing else.
My rear window did the same thing.... then quit. After 2 or 3 trips to Toyota and 8 or 9 hours wasted they finally diagnosed as a bad fuse block and replaced. Hope that saves you some time if that's what it is but I hope that's not what it is... if it hadn't been a waranty issue: >$900
Thanks...was it the fuseblock inside the dash or the one under the hood?
I pulled the fuse out of the dash slot because I don't want the rear window going down unexpectedly. So now none of my windows work until I can get the thing into the shop. Hope it's covered by the extended warranty.
