rear window washing nozzle
noLimits
Whenever I spray window washer fluid out the back it comes out as a small stream of liquid and not a spray. Is this normal?
I see your vehicle is a 2003 Limited. Mine is also the same model and year.
I find the rear washer does not work as well as I would like it to but mine also comes out in a small stream, not a spray. I find the wiper is not very effective more so than the washer. Mine has acted like that since I picked my truck up from the dealer, so to me, that is normal.
On the other hand, if yours used to spray out and now it comes out in a small stream, then that would be abnormal.
-Toy-Man-
sounds like the nozzle may be partially plugged. Not sure what the best way to clean this as it is most likely plugged from the inside.
You also might have a kink/leak in the washer tubing leading. I had another car that had that problem, but it was a pain in the ass to fix it so I lived with the little pee-stream of fluid. :D
I can make things easier for you. I never use the rear window washer because it messes up the lift gate. I can't stand the nasty black streaks it leaves when everything dries up. :D
I bet they made it this way because a cloud of spray might easily disperse in the wind, before making it onto the glass. A stream of fluid it seems would be more direct and effective. But that's only my guess.
I've used mine but once, but I can't recall how many streams come out. Looks like there are three ports in each of the front windshield nozzle.
