rearend swap
artcap9
Hi everyone I want to swap out my current rearend. The entire thing (shocks brake drums, axels, housing mounts all). is there a writeup some place for that. I have been searching for the last hour and have found nothing. I have a 1997 4X4 with 4.10 rear end and the donor vehicle is a 1997 4X4 4.10. My current vehicle has a leak and has 242000 miles the donor vehicle has 6194 miles and no leaks. Thanks in advance
ARTCAP9
I would just replace the axle seals and call it a day....diff gears last a long time before needing consideration.
Its pretty easy. I just did an E-locker swap.
#1 Drain Rear Diff. - 24mm Fill/Drain
#2 Jack up car on jack stands.
#3 Remove wheels.
#4 Remove 4 bolts sandwiching 3rd member pinion to the drive shaft I believe 12mm. Drive shaft will fall free.
#5 Next I removed the sway-bar I believe the 2 nuts are either 10 or 12mm.
#6 Upper control arms are 12mm and the lower control arms are 14mm I believe.
#7 Remove the pan-hard bar - 14mm socket
#8 Unhook the abs sensor wires that are clipped in 3 spots on each side.
#9 Remove abs sensors - 10mm bolt and pry out with flathad screwdriver.
#10 Remove E-brake cable mounting brackets ~6 12mm bolts and undo the cotter pin at each drum.
#11 Remove brake lines 10mm wrench and zip tie latex glove fingers to prevent drainage, ziptie to a high point.
#12 At this point the only thing keeping your rearend from rotating or dropping is the shocks. Remove those 2 bolts and TADA!!!! The whole assembly slides out!
If you think about it, it's really only like ~26 bolts. Took me and my friend less than an hour to remove it. I can post a more detailed procedure that combines Tq specs for reassembly if anyone is interested....otherwise just check out the sticky for Tq values.
Wait is your leak from the 3rd member pinion seal? Gasket seal? or one of the hub/axle seals. Cause if its just the latter you can replace it after step 3 above... 4 12mm bolts on each side at 53ft/lbs. Easy Peasy!
Thanks for all the replys. A special thanks to slickmastern that is just what I was looking for. It is leaking where the drive shaft goes into the rearend but I am going to change out the entire thing anyway (new shocks, drums, upper and lower control arms ect...). When you have time I would appreciate the torque specs for the installation.
Artcap9
Talyn
