if you have to add refrigerant you have a leak. the refrigerant does not run out, go bad,etc. Soap bubbles on the fittings works great. usually its a loose fitting or a bad hose. The charge amount should be listed on a sticker under the hood. You add to the suction line (usually has a blue cap on it). Leaving a known leak in the system can cause it to run low on refrigerant oil and burn up your compressor.
