Recommend a Portable Air Compressor
Jeffrey_VB
Any recommendations for a portable, 12v capable air compressor? Looking for something light/medium duty for topping of tires after a day in the sand, inflating air mattreses for camping, etc, etc, etc.
Wanna buy mine? I don't know what brand it is (i have to look) but it's made from China. lol User friendly. It plugs into any of your cig lighter sockets, hook up the hose to your stem valves, turn on engine and turn on switch. Yours for $20 (shipped). Lemme know.
$65 at overland. This site is managed by 4Runner owners.
Basic Air Compressor Kit
Would definately be interested in hearing more about it.
Don't know if you found a compressor or not, but check with your local welding shop, Airgas, or Richmond Oxygen and see if you can buy an old 10 or 15lb CO2 bottle and have them fill it. I get about 40 fills from a 20lb on 285/70-17 from 15 to 38lbs. You can get a preset 100psi regulator from them for 50 bucks and refills cost about 5 bucks. Great for tires and lockers, get a cheap battery inflator for your air mattress.
what about this one for a pump. Hrbor Freight has quite a few of this model and at 150psi, I would think that it would do the trick, even possible mounting under the hood as well?????
<a href="http://www.flickr.com/photos/36613889@N05/4618301523/" title="air pump by motox810, on Flickr"><img src="http://farm5.static.flickr.com/4037/4618301523_7e8aec7004.jpg" width="500" height="375" alt="air pump" /></a>
Best Value
I recommend this one: Amazon.com: Master Flow MF-1050 Tsunami High Volume Portable Air… Its pretty fast too!
but pepboys has it for $59 regular everyday price, which is where I bought it.
Many of us purchased this (or a very similar) unit a few years back when they hit the shore. Aside from a unique connector, these are solid compressors for the money. I have used mine regularly for the past four years. Unlike some of the '"toy" compressors that will take 10 - 20 minutes to inflate a single 32 - 33" tire , this unit is fairly powerful and will rapidly inflate your large SUV tires.
I wouldn't go with a straight air compressor, seems silly to use up space in the truck when other things do a lot more in about the same size device.
I got one of these a while back, and it has served me very well.
"When your car loses power, the Electromate 400 has enough power to both jump-start your vehicle and run emergency appliances such as portable lights, radios, cell phones, and small tools. The Electromate 400 is also ideal for non-emergency situations like tailgating parties, camping, power outages, and any other situation where no wall outlet is available. The two built-in 120-volt AC outlets allow more than one appliance to be operated at once.
There's also a built-in air compressor that allows you to inflate bicycle tires, sports equipment, and pool toys, but this compressor is also powerful enough to pump up the tires on your vehicle."
Amazon.com: Black & Decker VEC026BD Electromate 400 Jump-Starter with Built-In Air Compressor: Automotive
I've got this too. Also served me well, it powers a crockpot and TV at tailgates.
I just bought a Viair 450p. The portable kit for $299 on amazon. Haven't used it yet. Wanted something 100% duty cycle with decent output.
I have had a couple of these. They work really well when they work. Harbor Freight has great customer service so when / if it fails they will give you another.
Here a couple good links on 12 volt Air compressors, everything you wanted to know and more:
http://www.jeepforum.com/forum/f27/smittybilt-mv50-vs-viair-400p-they-same-compressor-834408/
http://www.jeepforum.com/forum/f27/harbor-freight-vs-costco-portable-12v-air-compressor-depth-review-w-pictures-378082/
I also have Viair 450. Quality unit that fills fast. However I man end up installing onboard air. One less thing to pack in the limited storage of the T4R.
Another vote for Black+Decker. You can consider this to buy this air compressor. Good one. I have seen a few other lists of compressors. Here are the best air compressors for home use. I like this list because most of them are affordable. But, If you believe in the quality then stick with Black+Decker.
