Well, now that my free oil changes are over, I decided to tackle the job myself to save a few bucks. The biggest reason was because some time back, I sourced about 150 quarts of Valvoline SynPower 0-20w for $1.00 a quart.
I picked up the filter and the crush washer at the dealer for about $6 and I read and re-read through all of the posts here and another thread. I also spent about a week and a half trying to find the correct filter housing wrench. One of the techs at the dealership was going on vacation for a week so he loaned me his until I can get one for myself.
When I drained the oil I was surprised how filthy dark it was. I have had the oil "changed" 5 times by the dealer at ~5k - 6k intervals with no hassle in regards to the coupons and the whole 5k versus 10k deal. This change was at 36500 right around 7k.
I say "changed" because after dropping the pan drain bolt with my 14mm and extension, my dad and I were both wondering if it had ever been changed at all. Needless to say I was a little pissed as I wiped down the pan, torqued the drain bolt, and buttoned up the oil drain cover. I then moved to the skid and the filter.
I had the truck up on my Rhino ramps so I had no worries about letting the skid hang as I felt that I would have enough room to work. The first thing I noticed was that the metal clip (what is this thing for anyway) was just past the mark where it should have been, indicating that at least my oil had been changed once, maybe. I grabbed my ratchet and extension and proceeded to remove the oil filter drain plug to drain the filter housing, and to my surprise, the whole oil filter cap assembly began to turn. I tried to hold the filter cap as I loosened the plug but no joy. That thing was tight. I am wondering if the dealer has a torque wrench in the place because it was well beyond the 10 ft lb spec.
Seeing that I was not going to be able to drain the filter housing, I decided to completely remove the skid to give me more room to make a mess. I definitely recommend removing the lower front bumper cover and that other doo dad from the skid to facilitate removal.
After that, I removed the filter housing, only slightly painting my right arm up to the elbow with black oil. The filter was as black as the housing, but I did not notice any metal particles glistening in either the filter or the bottom of the housing. We tried to hold the housing and remove the filter drain plug but were unsuccessful. I ended up putting it back on as it was.
When I take the filter wrench back to the dealer I am going to make sure to let them know that I didn't need it anyway because some b@st@rd tightened the drain plug too tight and the housing turned loose before the plug did. I am going to ask for a new housing and plug and they can have mine after the next change.
All in all it was a very simple job thanks to everyone who has done it before me and posted pictures and tips. In about 5-6k when I change again I will see how much difference there is oil color and the color of the filter. Maybe I can determine if they have been skimping on my free changes.
