Recovery strap recommendations?
el_kab0ng
I've been watching Ronny Dahl YouTube videos of his off-road 4WD adventures which has taught me alot about mods, recovery gear, etc. The question I have for the community is which recovery strap system do you guys use?
I'm thinking about the Zilla 35ft recovery strap since it doesn't require any metal parts and looks like what I need.
Zilla Strap - 2 in. x 35 ft. Recovery Strap | 4WheelParts.com
The only thing I can't tell is if it has the flexible shock load absorbing capabilities or if it's just a straight strap with no give. Have any of you guys used this system before? If not, what sort of system have you used and would recommend?
Yeah.. I like the idea of not having to use D-shackles, but it seems if I want the real deal (ARB Snatch Strap) then I'm stuck with them.
As others have said. . .ARB snatch strap. Used it on a few full size trucks, and on one I couldn't get to, we hooked it up to a tractor and pulled and f150 with no problem. I think for recovery gear or something like this, usually in these scenarios the last thing you want to do is go cheap and possibly cause a bigger issue if the item was to fail. But I always keep mine in the back in an ammo can with some d-shackles just in case. Hope it helps and good luck
Aftermath. It was up to the rails in a swamp
044runner4
