Referesh a 4runner-suggestions?
c0mmon
I have a 97 4runner i bought, runs great fantastic couldnt complain
but I want to refresh it just because, I'd like to challenge it a bit more than the pot hole riddened NJ streets.
I was thinking to change a number of bushings in the suspension/sway bars and the lower front ball joints. Anything else come to mind within reason?
Thanks for the help
Replace all the fluids, New radiator and new shocks. Original shocks will be worn out by now, so replacing those will be a big deal. And your rear coils will be saggy ass, might as well replace them, too. Of course by the time you replace all four shocks and the rear coils, you might as well go with a suspension lift.
If im going suspension lift-99 highlander springs good?
All depends what your going for. If you want a stock look 99 springs will be fine and you can use the 4600 bilstiens.
If you want a little lift get the OME coils and 5100 shocks. I used the 890 rear coils and left the front stock coils but used the 5100 shocks to lift the front.
Pics in my build for idea of what my lift looks like.
utkrstam
