Regear or new axel
Atreyus
Did some research but couldn't find a definite answer, would it make more since to regear my differential for around $700 parts and labor to 4.56 or find a axel from another truck and swap that in? I think I could get an axel for cheap at a junk yard but don't know what else I would need. Would it be just the axel or should I get the drive shaft too? Looking for the cheapest possible way or I might just drop my 31s back to stock 225/75/15 to get my power and braking back. Any info would be great thanks!
I'm running 285/75/16 MT's, no real maintenance to speak of, and I'm getting over 20 MPG on the highway. And it's actually pretty quick too. But a lot of that is due to the 3 pedals I think.
maintenance is great on it, it's just I have 31's on 3.7 gears, my brother has a 4x4 96 and i think his gears are 4.10 or 4.30 with about the same size tires 265/70/16 and I just want the extra pull, I am about 4 tire sizes up after all lol.
If you want to swap, you don't need to swap the entire axle, just the diff.
And used diff (if you find one) might be $100-200, just make sure it's the ratio you want.
Yeah, since you have a 2WD, the diff is all you need to swap out. I would go for 4.1 if I were you, they are the most common. 4.3 second choice. The 4.56's are pretty rare, so would likely cost more, but it all depends on what you find for a good deal I guess. Just don't limit yourself to only the 4.56.
I saw someone on TTORA selling a complete 4.30 rear axle with 4.30 for about $500. That would be a double win for you if you could get it.
BillM777
