Remote mounted radar detectors?
wkparker
I'm thinking of adding a remote-mounted radar detector to my T4R and want one that is as hidden as possible - only the display is in the cabin. Does anyone have any suggestions, experiences, or pics? Thanks
Boaz said:
want to sell it to me???
Sure... I paid $300 for it about 3yrs ago. Make an offer. Rather than sitting in the garage, I'd like to see somebody putting it to use.
It's not an active jammer, but a scrambler. It messes with the incoming radar and sends back messed up signal. If I'm going 45 the radar gun coupld read 115 one second, and 15 the next . I've seen cops hitting their radar guns as I drive by. Keep in mind, the radar will eventually break through the false signal and get a good reading. The bigger the vehicle the easier it is for the radar gun to get a good signal (4R will scramble good to about 150' of the radar gun).
Remote Radar Install
I recently installed the Belltronics 975r in my 2003 T4R SR5. It was a breeze and the system works great (1.5 to 3 mile warnings)!
It comes with a remote mounted multi-band antenna that I mounted behind the grill and two laser sensors (front/rear). The unit sells for $350 to $500 depending how well you can search for online deals. Rarely you can find one on eBay.
If you decide to buy the Belltronic unit, let me know and I'll guide you step by step through the install with digital photos and everything. I'm rather proud of this install. Check this out, I mounted the display unit inside the cubby hole that opens up at a 60 degree angle directly below the climate controls. Push the door closed and no one even knows it's there; push it open and it's at the perfect position for the driver to see and hear.
Let me know.
Mark
Make sure you guys are differentiating between a LASER and RADAR devices.
I was actually planning on getting a laser jammer on my 4R. The police here use laser to pull people over and radar for stationary photo radar.
iForce, the devices I am looking at *detect* both laser and radar - I haven't been looking at laser *jammers* (which, for the moment, are legal) or radar jammers or scramblers (which are definitely not legal).
Remote Rdr Bell 975r
wkparker: Your hard-drive audio install looks good. Okay so that takes away my primary mounting location.
I did consider an alternate location to mount the control unit. My alternate choice was inside the 12vdc power compartment. I'll get some pics of my install in the near future as soon as I'm able to borrow my daughter's digital camera.
Keep in mind that the control unit is only 3" Wide, 2" deep, and 0.6" high. I mounted mine with adhesive velcro. The radar antenna is the largest and heaviest of the four components. The two laser detectors are about the size of a thick domino.
Mark
Once you detect laser.. you're hooped anyways. At least here in Calgary you are. Police turn it on when they need to and shoot it right at your car. Detecting it would only affirm you're getting pulled over (if you were speeding).
Laser jammers aren't illegal here either.. except that you should turn off if the police should decide to pull you over because of the error reading he's getting. (lots of cars get an error reading should it wouldn't matter)
