The taillight screws/bolts are accessible from the pop out panels inside the cargo area to remove the taillights, behind jack/tool storage on the driver side and behind the sub or storage bin on the passenger side. I haven't taken off the panels, so I don't know if you can get access to the bulbs without removing the taillights.
The license plate lights are held in by two screws. Unscrew the two screws (four total for the two lamps), and the entire light/housing will pull out from the license plate garnish. Pop/pry off the clear lens to pull the bulb out.
