ShooterMcGavin
One of my rear sway bar end-links was broken a while ago. I was able to undo the bolt from the LCA side. I could not undo the bolt from the bar itself, so I cut the end-link and let it be. When I have a window open and go over bumps, I can hear the end piece rattle. The nut is frozen on the bolt and the other side is a ball joint that just spins. How can I get it apart?
Hmmm, I'm thinking, take the rear wheel off, for some space to work, and use something to cut the bolt off? Is there a trick to separating the end-link ball joint, in order to access the stud end under it?
