I'm just taking some auto classes @ FRCC. Working FT and doin some school on the side to get a FT job I'm passionate about. :thumb3:
I probably should have mentioned that I got the calipers from a junker off ebay, I live in a condo that doesn't permit the underground garage to be used for repairs and such. SO, I resort to using my wife's sisters' garage on the weekends. Since I plan to install them this weekend (limited time), I wanted to have them rebuilt prior to this weekend
At the time I posted, I wasn't able to hook them up and use the brake fluid to push the pistons out.
Thank you all for the suggestions....
zCruiser: Sorry, didn't take any photos, I can, however, walk you through the process I used for the 231mm 13WL. If you are rebuilding the 199mm, the rebuild kit, retaining springs, etc will vary slightly.
1. Get the caliper overhaul kit (includes goodies for one SET of calipers), shim kit(again, includes everything for one SET of calipers), caliper pins, cotters, retaining springs and pads from the dealer (cheapest I found was @ 1sttoyotaparts.com). For my rebuild I reused the OG caliper pins, cotters and retaining springs.
2. Pull em apart! Remove cotters, caliper pins, retaining springs, pads, shims. Save the cotters, caliper pins and retaining springs. Replace them if they are excessively worn or damaged.
3. Remove piston dust boots(4) with pliers. There "should" be a "set ring" on each piston that secures the dust boot to the piston. I say "should" because mine did not have them when I disassembled the calipers. These are reusable, so keep them as the caliper overhaul kit does not include these. Take care not to damage the machined surfaces of the piston during boot removal.
4. Now it gets fun. There are many different approaches to this step, but basically you want to use the air to "blow" the pistons out. Get a small block of wood (2x4 or 1x4?), place it in the negative space between all pistons (IE: where the brake pads would be). hook your air nozzle up to the brake fluid inlet (use about 30-40 psi, carefully) and let er rip. The wood is used as a cushion for the pistons so that they don't collide with one another while shooting out. They come out with a great deal of force, so watch those fingers!
The pistons should pop out and smack the block of wood. If they don't come out far enough, try again. If one comes out and the others are still recessed, replace the piston and reposition the block. Try again. Get them all out. If they still aren't coming all the way, It's okay (but not reccommended) to use some pliers on the OUTER most lip of the pistons to twist and work them the rest of the way out. Make sure to make a note of which pistons were installed where. It's best (as I've been instructed) to maintain that order.
5. Your pistons are out. Now, remove the piston seals from the inside of each piston housing(1 per housing, 4 per caliper) Take care not to scratch or damage cylinder walls.
6. Clean the calipers, pistons, etc with brake cleaner. remove any rust. get em nice and clean.
7. Now, pop open the caliper rebuild kit. There should be a packet of PINK lithium soap base glycol grease. apply the grease to: Cylinder walls, pistons, piston seals and piston boots, ONLY. I would suggest that most of it be used to grease the cylinder walls and pistons. Definitely hit the seals too, but the boots aren't as much of a priority(imo), since the amount of grease provided is limited.
8. Install supplied (caliper rebuild kit) piston seals
9. Reinstall pistons. I pushed mine ALMOST all the way in. Leave them 1/4" out - makes it easier(IMO) to install the piston dust boots.
10. Install piston dust boots. I stretched the inner part(attaching to the piston) first, then the outer part that goes around the lip on the outer edge of the piston wall.
11. Reinstall set rings around the piston/boot
11. Prepare new pads, shims. Use the black colored "anti-squeal" grease (provided in the shim kit) to cover both sides of the slotted shim. Mate the solid shim to the slotted shim and then mate that assembly to the back of the brake pad. Take care not to get any grease on the brake pad, itself.
12. reinstall pad assembly(ies). First, clean the pins, cotters and retaining springs. Then, use a hightemp grease and lightly coat the pins. reinstall the pins, cotters and retaining springs.
13. enjoy your freshly rebuilt calipers.
I used the FSM (exploded view) -caliper diagram to make sure I was reinstalling all of the parts correctly. It was extremely useful as I am the type of guy that needs to see it, rather than read it. Sorry I don't have photos, but this mini-writeup (coupled with the FSM page) should be more than enough to get you through it easily. Brakes aren't nearly as complicated as I thought.
EDIT: I also referred to this webpage for a visual. The steps/parts are similar.
step by step photos .
