removing splined coupler on transfer case?
jkeith.w
Official Vendor
Does anyone have a clever technique/method for removing the splined coupler from the transfer case without damaging it?
I couldn't get my 3-jaw puller to grab the back without slipping off... :nono:
You see those Knipex Cobra's on the ground? You see the bluish discoloration from heat on the stock coupling? Yep. I used heat. Then grabbed the coupling with the Cobra's and beat the coupling about 1/4" out. That allows you to get the puller jaws in behind it.
I used a small chisel to get it started and a hammer and punch the rest of the way...wasn’t difficult...thinking I got lucky.
What's the procedure to re-install the coupler? Mine is off and I need to put it on. TIA!
