Removing the front bumper?
Dous
I have a 99 Base 4runner with chrome bumpers. I am trying to paint the front chrome bumper but am having a good bit of trouble. I got probably 15 bolts off and it wouldnt move an inch. Is there something I am missing?
its 4 bolts exactly. They are on the interior of the bumper, located about an inch closer to center from the turn signals. one up high on the bumper, one lower. lie under the truck and check it out. they are pretty visible. Im pretty sure its a 12mm. I had to take mine off a few weeks back. You will need a deep socket or open ended wrench.
Put those 15 back and take off the right ones. Are you separating the lower valence from the bumper? that accounts for 8 bolts. plus a 4 pressure tabs for the turn signals.
Okay so if I remove those 4 bolts will it remove the valance, the bumper, and that little plastic trim piece that sits above the bumper right bellow the grille?
Yes. Just make sure you unhook your turn signals or you'll rip the wires out. :D
I had to take mine off to straighten it. 10 minute job.
also- you may want to re-think painting the chrome bumpers...I haven't personally tried but I've heard it's hard to get any kind of paint to stick to them...
I left the valance off mine and love the look...
take off the valance and the bumpstops for added entry angle if you 4wheel,
leave it all on if not...
I agree. I did mine. A few times to get it right.
The first couple times I did a light sand and some rattle can. Never really stuck for too long. if your going to go this route, I would recommend a wire cup brush or grinder to really get into the chrome. The general rule of thumb is that if it shines, spray paint wont keep.
Hurculiner did the trick! Go that route. Plus its more durable to trail rash. you will be painting the bumper again if you do any serious wheeling, if you go with spray paint.:roadkill:
Well, I painted the rear one last week, first scraped it up, then did an adhesion primer, then paint, and finally an enamel. I still seems to be holding up okay, I took to mudding already, and scraped against some brush and it seems to be okay. Where can you get herculiner?
Like others have said, you will really need to sand/grind on the chrome hard to get any kind of paint adhesion. Without good sanding it might hold up for a few months, but after that you will probably start to notice the paint flaking off in places.
Word.
As far as where to pick up hurculiner, any auto parts shop like an autozone or napa should have it. It comes in a paint can. I hear duplicolor bed liner is nice too and comes in a rattle can. I have not tried it though. I threw on three coats of hurculiner and it has help up awesome. I have re-applied once, but the first round lasted 3 years. not to shabby for under $100 to do both bumpers and rocker panels (About 3 hours including cure time). A good amount of the cost is attributed to prep supplies like tape and rollers, so if you have them already, it should be between $40-80, depending on the size can you get. I went with the full gallon so I could really lay it on. I do recommend green painters tape over the blue. You get a much better line with it.
There are extensive threads on hurculiner in the forum, but I would be happy to give any help and opinions that might help.
Thread revival...I want to take this plastic off...couldn't find anything that said how it comes off...just brute force?? :thanks:
Here is how to do it.
[/URL]~original[/IMG]
I'll shoot for a deer....since I've almost hit 2 in the past couple days (plus, venison is a bonus)...although, our Maine turkeys are big....and tasty
If you have the option, aim for a moose. You have those around you, right? That'll take the bumper trim off. Plus, moose make lots of meat! But venison is great too.
