4 4runner32 Guest Oct 25, 2008 #1 My hitch is begining to rust pretty bad... How should i do this sand it down then repaint it?.... What kind of paint should i get?
<<<< Senior Member Nov 7, 2008 #2 POR-15 is the best for frame, no sanding needed unless major amount of rust.
K KarenCaren New member Apr 22, 2009 #4 Sanding first will make the paint out better. If you are good at painting you can use paint from spray can. _______________ If you ain't first your last! 4runner performance parts
LINY4Runner New member Jul 12, 2009 #5 i've been wanting to do this for a while. i plan on sanding it, then spraying it with undercoating
