Has anyone replaced the grommets holding their 99 fog light brackets together? The fog light bracket is two sub-brackets held together by a single bolt and two brown grommets. The grommets on my left bracket have cracked, allowing the foglight to move, causing the beam to bounce around.
The local dealer was unable to pull up a part number for the grommets. The parts diagram shows the entire bracket assembly only, without the grommets broken out. Does anyone know of a part number or source for these grommets? Replacing the whole bracket seems overkill, wallet-wise.
-RC
-RC
