Replacement Rear Axle housings and Wheel sizes, do they matter?
04yfz
Backstory (feel free to skip):
I recently purchased a 4runner and unfortunately before I got around to changing all the fluids I seem to have a whining/bad rear diff due to low/possibly no rear fluid. What the previous owner failed to mention was the leak in the rear diff (caused by rust pinholes). If only I had known I could have saved the gears and just fixed the rust temporarily until I found a replacement housing. The diff was fairly dry which leads me to believe it was ran without oil for a while.
Anyway, I am looking around for used REAR axle housings/diffs and it seems as though many junkyards ask for wheel size 15" or 16". From doing some searching, it seems as though the wheel size only makes a difference on the front wheels, due to larger brakes on T4Rs with 16" wheels. However, before I purchase an assembly, I'd like to know if they are indeed the same in the Rear or if they are compatible? If the drum sizes are different are,they swapable?
Any help would be appreciated, thanks!
rear axles only differ based on the existence of a rear Elocker, do you have one?
I have a non-elocker housing for sale practically rust free for $50. I hope you are nearby..
No I do not have a locker as I have an 01. That sounds like a great deal but I am in New Jersey. If you would consider shipping through something like forward air let me know via PM. I have found a set of gears so that would work.
DJNutshell
