moretoys4me
Would like to replace my radiator coolant at 60,000 mile on my 05 V-6 SR5 runr. Heard the best method was to drain radiator, add distilled water, run engine till warm, drain again, then add 50/50 mix until full. Will this method drain the engine block and also I've been told that thermostat should be removed after first drain then flush system? Not sure if this is required. Is 60,000 miles also reasonable? Using Toyota red Long Life coolant.. Thanks in advance for your response....
