Replacing CV Axle - got ?
Pretty sure these are the ones you want (call camelback to verify).
https://parts.camelbacktoyota.com/p...bgroup=FRONT AXLE&component=OUTPUT SHAFT SEAL
They are side specific so you need to make sure you get the right ones installed on the right side. It would be impressive if you got them backwards but just worth saying.
These are the seals at the diff. There are also seals at the spindle that are worth replacing as well.
https://parts.camelbacktoyota.com/p...=SUSPENSION COMPONENTS&component=Knuckle seal
Good luck!
H.Sikina
