Replacing Negative Battery Terminal?
Kirk_B
Member
Which connectors has everyone used that have had to replace their negative terminal ends? I used a genuine Toyota positive terminal end, but can't find a part number for the negative.
the negative terminal is crimped into the wire so it's not a replacement part from toyota unless you buy a wiring harness no 2. you can buy quality terminals on amazon or auto parts store. and battery cable eyelets, some solder and crimp them. you can check out
http://www.toyota-4runner.org/3rd-g...wiring-ugrade-3rd-gen-toyota-4runner-how.html. shows you how to do thebattery wire terminals in this writeup.
If you do end up crimping a ring terminal onto the factory negative cable, Toyota does sell a negative terminal to match the positive. I found it on a late 90s early 2000s Camry 4 cylinder. Its an exact mate to the positive used on our 4runners.
DionicioLives
