Yes that is correct, I have already done this. Be sure you have it on the odometer setting, then turn off the key. Then hit the re-set button and turn the key to on and hold the re-set button. Pretty easy really.G.I.G. said:Hold down the odometer reset button while you turn on the ignition. It will take about 5 seconds than it will blink and go off.
wasn't it 5000 mile intervals??? Can this be changed?
