WTS said:Hi Koz,
Thanks for the info. I don't think I'll be doing alot of off roading or alot of towing, so I guess the P rated is the one to get for me. But for all the reviews, like on tirerack, which rating would most of them be talking about. I suppose thats anyones guess.
So would both tires be ranked the same ie: same tread wear, same ride, same noise, same handling on pavement etc. Baffles me how each size, rating etc of the same tire can be or have the same results or be ranked equal.
WTS said:Hi,
Which rating for Revo is the most used the P or LT rated version. What are the differences between the two versions?
Walter
pipspeak said:If you don't do much off-roading get the P-rated. The LTs will give a much harsher road ride in general since they're much stiffer and heavier. I had LT tires on my old Jeep and sometimes it felt like my tires were made of wood.
teotwaki said:I have not had such a bad experience. I went from the stock Dunlops to the Revos and feel that I ended up with much better handling.
