Ribbon cable for limited heat/ac unit
Skibber
Does anyone know the part number or where I can get a replacement cable that connects the 2x boards in the unit? I bent a couple of the prongs and can't get the cable to seat properly now.
Crisis averted! I ended up cutting the conductors back flush to the ribbon with scissors, then scrapped away the shielding with a knife edge on one side to reveal the conductors.
Saved me a few bucks and some days without heat.
FYI...the cable spec was in fine print on it: "Sumitomo-Y AWM 2896 80C VW-1". It is a 10 Pin Flex Cable.
What you did is what I do when I have this problem. I'm sure you re positioned and glued the little plastic piece to the back of the contacts. The part is available by the way.
https://parts.conicellitoyotaofconshohocken.com/oem-parts/toyota-wire-cooler-no1-8848435020
PRWhite
