Ridgid RO230 - battery pack compressor vs Viair 88p
MSRP.
Hi folks,
Has anyone been able to find a duty cycle number on the Ridgid R0230 to compare to the 88p?
Price difference is considerable, as is the size, but I already have quite a few Ridgid batteries for power tools and the added utility of a small tank (for me) justifies the additional cost..
88p's specs:
12-Volt – Permanent Magnetic Motor –
Duty Cycle: 25 min. @ 30 PSI – Max. Working Pressure: 120 PSI – Max. Amp Draw: 20 Amps – Ingress Protection Rating: IP53 – Max. Ambient Temp: +158°F – Min. Ambient Temp: -4°F – Dimensions: 9.8″L x 3.2″W x 5.6″H – Net Weight: 4.75 lbs. – Power Cord Length: 10 ft. – Air Hose Length: 16 ft.
@40psi 1.15CFM
@90psi 0.64CFM
88P Portable Compressor | VIAIR
Ridgid R0230 specs
Air Delivery SCFM @ 40PSI 1.4
Air Delivery SCFM @ 90PSI 1.0
Maximum Pressure (psi) 120
Portable Yes Amperage (amps) 0 A Power Source Rechargeable Battery Application Use Finish Nailing Product Weight (lb.) 19 lb Compressor Tank Capacity (Gallons) 1 Returnable 90-Day Compressor Type Trim Stage Count Single Stage Compressor/Air Tool Features Automatic Shut-off,Handle,Oil Free Compressor,Tank Pressure Gauge,Universal Quick Connectors Tank Material Steel Decibel Rating (Outdoor) 77 dBA Tank Style Horizontal Horsepower (hp) 0 hp Tools Product Type Air Compressor Included No additional components or accessories are included Twin Stack Tank Configuration Yes Lubrication Type Oil Free Voltage (volts) 18
RIDGID 1 Gal. 18-Volt Hand Carry Air Compressor (Tool Only)-R0230 - The Home Depot
bobdjr41
