Rigd Supply Ultraswing Tire Carrier
I thought the pro came with a spare pro wheel ? I like the de tours tire rack more as it has the adjustable tire depth and lower price.
Thanks for sharing this. I really like how close this one fits, versus the RIGd UltraSwing. It would be nice however if this particular unit allowed for a bike rack to swing out with the tire, like the UltraSwing. Do you have a link where you purchased this one? This is a great option, especially for those not needing the bike rack option.
Detours of Maine
I actually don't have this, I just remember it from a previous topic. So it may be compatible with a bike rack, I just don't know. Doubt the bikes would swing out also. I also like the fact that it sits close to the 4Runner. It doesn't come powdercoated so possibly a reason why it is cheaper.
building a 1st gen rear bumper, can you tell me where you got your latch system? used 4x innovations last and it squeaks a lot and bounces more than id like.
Am I missing something but none of the pics have lighting in the rear plate? Isn’t this a legal requirement?
True, you have to be a little creative with Amazon and a roll of 14ga wire...
That said, I have had mine installed, with no light yet, for close to two months and no one has said a word.
A little creativity is a small price to pay for a fantastic product. Solidly built, looks good, allows some flexibility with accessories...I use mine with a 4gallon Roto Pax. It is the alternative answer I was looking for to a full aftermarket bumper. No regrets and highly recommend!!
AMLOR
I have this wired to an adapter that connects to the trailer plug. Comes off easy when I remove the Ultraswing.
There are also license plate bolts that have LEDs. Seen other people use this method.
Thanks. My comment was not specific to this brand. I don't think any of the brands cover that.
Just seems that with as much as they charge, that should be accounted for. Might look into the LED bolts and order this.
Can you post the details on the adapter that fits the trailer plug?
Take this, Amazon.com: Wesbar 787268 Trailer End Connector Wire: Automotive, use the only 2 required wires (White and Brown) and then put whatever connector you want between that and the license plate lights to make it easy to disconnect. Works great. Maybe down the road I pull panels and wire something up but while deciding if I like the RIGd setup this has been working great.
I used this.
POLLAK 12-706 Plastic Blade Style 7-Way Plug from Amazon
What rear coils (springs) you guys have with the Rigd?
I am using Eibach's Load Leveler system. It is adjustable, and an amazing bit of design work.
I am currently running the 250 lb spring set, but after adding the UltraSwing, 4 gallon Rotopax, and tire and wheel combo, along with everything we need for a trip, I will be changing to the 400 or 500 "pounds over stock" springs.
The steel Strongbox drawer set is 115 pounds empty. The UltraSwing is about 68 pounds, tire and wheel about 75 pounds and the Rotopax about 30.
That's just under 300 lbs and I haven't added any "road trip stuff" to the totals.
That's mine...of course YMMV.
Amlor
Ive been rolling around with the ultraswing with no light on my plate for almost 6+ months now with being tailed by cops multiple times on the road (even at night); even seen a couple looking down at their computer appearing that theyre just running plates to find someone to pull over for quota needs... despite that never pulled over. had even a couple of cops just signaling me to roll my window down for them to compliment the truck. honestly as long as you're not being stupid on the road and your tags are up to date i highly doubt you'd be pulled over JUST for that
wayblom
