TotalAutomotiveLV
A lot of the new items for the 4Runner are not released yet - but will be available for preorder
If you plan to post to Classified forums, you must follow these rules, or your post will be deleted.
Do you know how the grill installs by any chance? I tried contacting Rigid and never heard back. I'm just wondering it you have to remove or cut your current grill. Thanks.
I am definitely interested-- what is available for the '15?
Are the replacements for the factory fog lights much brighter?
No "cutting", you do have to uninstall the current grill. It is 100% reversible, if you need to.
Please Pm.
2014 4runner trail edition, grill + light.
The new grille for now. (and I think some others, I don't know... as they are not public info)
Replacement fog lights are depending on which Dually or D2 that you put in. D2 are much brighter than Dually. There is also the new and uniquely Rigid's D2 H/L Driving Pair which features a 20% brightness setting and full blown 3096 lumens each. Lastly, they have the new SAE/DOT approved Fog Light set.
So, it's your choice to make it how bring you want. And you can put colors cover on them (ie. Amber etc..)
Looking at the specs for the SAE/DOT Fog Lights are 1760 lumens compared to Dually that are only 1568 but not as bright as the D2s
Those are basically the "spec", their beam shapes are different too. So, its all depending on what you want and how you want to use them.
I've also read that if you put an amber cover over the housing, the light output reduced by ~50%. I'm buying a set though - just don't plan on going amber.
