Roof Rack Options
Victory 4x4
Official Vendor
Roof Rack Crossbar | 5th Gen (10+)
Designed to work with your stock rails and support any gear you might need. (RTT, cargo, etc...)
CNC cut and formed from .188" steel.
Drilled and slotted for 5/16" mounting hardware.
Sold individually.
Proudly designed and made in the USA.
The number of rails needed will depend on the cargo you plan to mount.
5th Gen Roof Rack
4RUNNER ROOF RACK | 5TH GEN (10+)
This roof rack system allows for mounting almost anything, freeing up valuable cargo space for other trip essentials. Comes coated with a 2 stage satin textured black powder coat over durable zinc primer finish.
  • CNC cut and formed from 3/16" aluminum (steel mounting brackets) with extruded aluminum rails
  • Easy bolt together installation
  • No drilling required
  • Available with or without 40" lightbar cutout (on the full-length rack)
  • Milled T-nut access points
  • Fairing Edge Trim Included
  • Powdercoated
  • Hardware Included
  • Made in the USA
  • Free shipping!
Install Video
Standard Length Roof Rack
Our 5th gen roof rack is also available in standard length!
It uses the factory mounting locations and is about the same length as the factory rails.
LADDER Options?
OK, I've been patiently waiting for a Victory hatch ladder option for my Victory full rack, but the stubby option that I can get with $2500 of rear bumper and swing outs isn't for me. I need to know which models out there are compatible with victory's roof rack (won't bump or rub the rear of the rack).
I'm looking at Gobi, BajaRack, C4 Fab and GreenLane Offroad. Anybody have one of these installed with your Victory roof rack?
Thank you.
Hatch Ladder?
Not at the moment, but give the sales team a call and tell them you are from the forum. They may be able to get you a deal! 269-459-8447
I haven't seen any comments from Victory in this thread in 6 mos...please see my post (above)... any movement on producing a Victory hatch ladder or are you aware of which 4Runner ladder models (Gobi, BajaRack, C4Fab, GreenLane) are compatible with Victory's full rack, as the rear of your rack is somewhat unique. Thank you!
I'm sorry about that! A Victory hatch ladder is not currently in the works yet. Some have run other ladders with success.
Here is a quote recently from our Roof Rack thread. Other ladders may fit without any interference. If the rear fairing does interfere with the ladder, it can be removed, as it is just there for aesthetic reasons.
"I have the full length rack coupled with the Gobi ladder. The top corner of the ladder does make contact with the rear fairing of the Victory rack and prevents the hatch from fully opening by only about 1-1.5" (if measuring the upward travel of the bottom of the hatch door). This can be solved by either removing the fairing, or maybe removing a small section of the fairing to clear the ladder."
AndiGarage
