Roof Rack System
rufflz
Hey team,
Miraculously landed a Can-back top for my 1st gen 4runner and now looking to integrate some type of roof rack system.
I placed an order for these cross bars (on back-order) through Bryon at Truck-Candy, but they're just a bit steep at $220/piece.
Does anyone familiar w/ Can-back know if I could use some Thule Cross Bars instead?
Thanks in advance!
- Ami
I don't have any experience with the crossbars you are asking about, but I use a safari rack basket (aluminum) on my Can-Back using some stainless U-bolts to secure it to the Can-Back bars. I'm going to make a bigger rack at some point and probably just use U-bolts again because they are simple and effective.
Why are you in need of cross-bars for a basket when your top already has two bars that can support 350lbs?
A problem well-stated is a problem almost solved.
Exactly where do you want to install your cross-bars?
On the metal cabin roof? ABOVE your soft-top?
A clear picture paints a thousand words.
If above your soft-top, are you willing to put holes on your soft-top?
If not, you would have to find a rack that mounts ON THE BODY over the soft-top.
$220 for cross bars? Checked Craig's list for used, high-quality Thule?
pm'd
Apologies for the confusing OP/question.
The cross bars would be installed above the soft top. My question was whether I'd be limited to just can-back cross bars or if I could go w/ another brand like Thule instead since I didn't know if the Can-Back would support any other type of bars. Only reason why I'm asking is because $220 per cross-bar from can-back seems a bit spendy.
The cross bars would be installed above the soft top....
I see. Not knowing/seeing your Can-back setup (a clear picture paints a thousand words), and knowing that most soft-top fabrics go OVER the frame , I would assume the mounting for feet of the crossbar would have to penetrate fabric of your soft-top. Most likely, other brand may not have the special setup for that so Can-back's own product would be your best bet.
Finally got around to snapping a pic of the croassbar.
You can see it is a two piece mount. THe bottom could be made out of a piece of angle steel, and the top is clearly proprietary, but I bet you could use any generic roof bar system that attaches to a drip rail.
DJNutshell
