rough idle
markdifferent
hello all. i will try to explain this as clearly as possible. i have a 1990 t4r. it has 145k on it. and the v6. when i got it there was a slight miss. it has never stalled but it can be rough when at a stoplight. after doing a tune up, to include new plugs, wires, dist cap, therm stat, rad flush, ac flush, oil change, trans flush and filter, as well as plenty of fuel injector cleaner. well i still have a rough idle. oh and by the way had the mechanic look it over and he said the motor was clean, i was worried it was a burnt valve. so now i have a good ride, until i get to a stop light. then i am shaken . on another post i saw sea foam, so i tried it today. i cleaned the throttle body, and put half a can in the brake booster line. then i put the other half in the crankcase. i also put another can in the fuel tank. this helped the rough idle a bit, but i decided to change the idle speed, is that bad to do? what else can i do or should i have done, and 1 more question.,anyone had the recall for the steering done and it seemed to make things worse? i have so much play it seems now and its starting to worry me. thanks
before i messed with the idle speed it was at 500 maybe a touch below. that was in gear, now i attempted to raise it by turning the nut and using the allen wrench on the bolt on the throttle body. then i used the idle screw to tune it in more. i am now running at 750-800 in gear and 1200 in neutral
thanks. i took alot of time to read and re read the info on the page you posted. alot of good info there. but i am not sure my problem would fit in this solution.
Symptoms of a bad or mis-adjusted TPS include:
* Varying idle speed
* Hesitation while accelerating
* Poor fuel economy
* Inability to correctly set base ignition timing
i have a steady idle speed. acceleration is decent for the v6, and i usually get 280 to 300 miles to a tank highway. is that normal or should i expect more? i adjusted the allen bolt that provides more or less tension to the throttle cable, then tuned it further with the idle screw.
Do you smell fuel under the hood after you turn the motor off? I had the same symtoms you do. I figured out it is the fuel damner/pulsater after it started to finally leak fuel. from Toyota they're @ $120. A junkyard should give you one for @ $25.
no i dont smell fuel, at all, and there are no lights on check engine etc. i have been tryin to find someone that has the computer reader so i can hook it up and see whats really going on. as far as parts my good friend owns a salvage yard and sets back all the 4runners for me to go thru so any part i need i get for free. i am thinking of just getting a newer motor to put in it. will the 3rd gen motors fit? thanks i appreciate all the help i can get. by the way i honestly dont have a clue where the fuel damner/pulsater is. would it cause the rough idle? and if so would setting up the idle speed cure it or would i still need to look into a replacement
When mine was doing that a few years ago with just over 100k, it ended up being a burned valve. I still have that valve sitting on my workbench in my garage as a reminder.
Good luck!!!
Gonna throw my 2 cents in here to. Vacumm leak? Intake gasket leak? If it is in intake then you may see a very small fluid leak on the edge of the intake, so small to the point that it looks discolored or small drips of green rad fluid. I had this happen to me once on a truck we had and I spent months on the bad idle to find out that the intake as leaking. Could cause the odd idle problems. I would check those before throwing away a good motor. Listen for any very slight sucking noise. if you can hear one then likley it would be the cause of a small carb hose or smog hose line that is cracked or leaking.
just my 2 cents
:: Edit ::
Forgot to add that if that is the problem you will need to re-adjust your idle back down as you have tryed to raise idle for a problem that was not nessarly related to the idle which will cause your motor to idle very high and burn fuel like, heating issues etc..
