markdifferent
hello all. i will try to explain this as clearly as possible. i have a 1990 t4r. it has 145k on it. and the v6. when i got it there was a slight miss. it has never stalled but it can be rough when at a stoplight. after doing a tune up, to include new plugs, wires, dist cap, therm stat, rad flush, ac flush, oil change, trans flush and filter, as well as plenty of fuel injector cleaner. well i still have a rough idle. oh and by the way had the mechanic look it over and he said the motor was clean, i was worried it was a burnt valve. so now i have a good ride, until i get to a stop light. then i am shaken . on another post i saw sea foam, so i tried it today. i cleaned the throttle body, and put half a can in the brake booster line. then i put the other half in the crankcase. i also put another can in the fuel tank. this helped the rough idle a bit, but i decided to change the idle speed, is that bad to do? what else can i do or should i have done, and 1 more question.,anyone had the recall for the steering done and it seemed to make things worse? i have so much play it seems now and its starting to worry me. thanks
