4runnerWiniarski23
Hey guys, I recently performed a head gasket replacement on a buddy's 4runner, 01 Limited. It's not my first time doing a head gasket. We got everything buttoned up yesterday afternoon and fired up the truck only to find it running very rough and dying. It would not run.
We tripled checked the timing before closing everything, rotated the crank twice by hand everything lined up great. Is it possible to jump timing when first starting it up?
So far we swapped the plug wires, truck runs but is very rough still. Giving it some gas smooths it out but it won't find a clean idle.
Vacuum leak or intake leak are what we are thinking. (Low rpm to much air engine rough, higher rpm the extra air is OK engine smooth)
We did have two vacuum line connections that did not have a line to hook up to after removal. First is the vacuum line to the left of throttle body, researching where this needs to hook up to.
Second vacuum line is at the back of engine exactly where the fuel supply line runs, it's a vacuum line connected between the two cylinder banks with a y connector but no line. (Attached photo)
