Hello. I'm a very new owner of a fairly clean 06 SR5 4x4 with 120k miles. I am a member if other car forums and understand how the search function works. I have looked through many threads and have found some very good info concerning the issue I am having but I do have some questions that are specific to my situation.
Here is my current issue and any help will be greatly appreciated. I should also include that I am able to do most repair work myself. If it is over my head, I will take it to a shop.
Upon startup, the engine will crank for a couple of seconds and turn over. However, once it "starts" it is very weak and nearly stalls completely. It will then pick up the rpms and operate as normal. No issues while driving or idling.
Since I have noticed this problem, I have tried to prime the fuel pump by turning the ignition to on and waiting about 8 seconds. Then I turn it off and back to on to build fuel pressure up in the system. This still does not help the startup.
After it has been operating normally, I can turn it off and back on without the hesitation. However. If there is any significant amount if time between then the startup issue returns. By significant I mean 20 minutes.
Could this be a bad check valve that is not allowing FP to build up enough? A weak fuel pump? Can you replace just the fuel pump or do you have to have the entire assembly? Could plugs be the culprit? Any sensor that is know to cause this problem?
It runs and operates normally once it starts up
Thank you all
Thank you all
