Rubber Fender Flare Trim
Hepar
Does anyone know what the part numbers are for the rubber trim on the larger SR5/Sport flares for the rear? Millennium silver specifically. I can only find part numbers for the front.
As well as I"m having trouble finding the rubber trim that goes around the rear license plate bezel. That's a dark grey. Not sure what specific color it is.
I don't quite understand what you're looking for. Are you referring to the rubber that goes between the flares and the body of the truck? Maybe insert a picture of what you want
Yeah. The weather sealing rubber trim between the fender and body. Pic? Good idea. Part #13 in the picture for the fronts. But I can't find them for the rears.
parts_example_zpscjbpb62x.png~original
I have some of the black rubber moldings at home, i can pull the part number. Just to warn you, its about $250 to replace all of the pieces on the four wheel wells (for a 97 limited at least)
They come rolled up, and the right and left sides are interchangeable, so you may only see part numbers for each side.
My license plate doesn't have rubber, it seems to be plastic on paint which probably explains why it's starting to rust. Thanks for asking this because after I take it off to fix the rust I was planning on using some rubber there to not only protect from chafing but also to cover up my rust repairs. :doh:
