034runner13
I have been having a very loud rubbing and grinding noise when i make a fast sharp turn with my 03 4runner and i can not find out what it is. It is driving me nuts. Any ideas any one go threw this before?
You probably need to grease the steering stops, that's what it was on mine. Only happens at lock and near lock conditions. You can also go to the dealer and buy the original plastic caps which wear off.:cheers:I have been having a very loud rubbing and grinding noise when i make a fast sharp turn with my 03 4runner and i can not find out what it is. It is driving me nuts. Any ideas any one go threw this before?
I have a similar problem. I would like to know more about these steering stops.
I don't know the part number but it can be obtained at one of your local Toyota dealers. I have looked through all the pictures I have of the 4th gen front end and can't find a picture for you. I would suggest turning the steering wheel all the way to one side and crawling under to take a look at what stops the steering from turning further. If that wont work the dealer can show you better pictures than the service manual provides.:cheers:it kinda sounds more like a rubbing noise. It doesent do it in reverse but it is definently only at full lock or close to it. wheree are those stops exactly and does anyone know the part number for those caps
x2 please
Thanks for the picture. Does that just get covered in grease? No zerk anywhere? I will take a look at it in the morning, but it seems like it should have a rubber bushing or something similar.
Thanks Chris I just didn't know how to describe it.:thumb3:Try some grease. The pic below is the drivers' side. The passenger side is the same and needs grease too.
This is the "stop" for the steering limit. When at the limit or very near the limit a minor bump causes the this area to rub the LCA (lower control arm) and make the noise you don't like.
:cheers:
Does the Grease have to be applied with a grease gun, or can it be applied by hand by just rubbing the grease?
And if you can do it by hand, how much and where do you grease. I want to get rid of this terrible/embarrassing noise ASAP.
thanks.
I usually take 1-2 pump out of the grease gun onto my gloved finger and then wipe the surface shown in the pic. Good luck!
:cheers:
check your wheel bearings, there has recently been some on this forum with 03 s that had the same issue ? thats what it turned out to be.
How would I go about checking the wheel beraings, and what should I look for? I am a handy guy, but do not know alot about cars. If I had instructions I could definitely figure it out.
Thanks.
