I think e85 is 85 percent ethanol. No, we can't use that. You need 92 octane in a supercharged 5vz.
It's been shown that's a myth. Many 95.5 - 04 tacoma guys are running e85 in their boosted builds, same fuel system.Well also keep in mind these vehicles were not designed to run E85 so I would be hesitant to use it. The fuel hoses are already old, and the E85 degrades rubber lines, so something to keep in mind
You'd need both. Best would be to first research forums, then to call gadget at urdusa.com and he can steer you in the right direction. We dont have e85 up here or i'd be trying it.[MENTION=85423]Greg_Canada[/MENTION] I dont have large fuel injectors just stock. But i was thinking about getting the 7th injector would that help? It's stock ECU.
Don't listen to this guy. He has no idea what he is talking about.
@Greg_Canada I dont have large fuel injectors just stock. But i was thinking about getting the 7th injector would that help? It's stock ECU.
my .02:
If your not currently experiencing any predetonation(read knock) then you probably will not benefit from E85. It is ~105 octane(anything over 100 octane is calculated, not measured, hence the variations from different people).
the stoich of e85 is something like 9:1(don't quote me), and therefor requires more fuel to burn properly. about 30% more than gasoline. So you'd need to have approximately 30% larger injectors and fuel pump, as well as a fuel controller. the factory ecu isn't going to figure it all out on its own.
If your at sea level and struggling to get your 5v"Z"fe to run without knocking you should definitely start reading up.
Untrue, just because he isn't experiencing knock, does not mean the ECU is not pulling timing. The toyota ecu advances timing until it knocks then backs off. With the e85 it will run more timing.
Are you sure?
Your argument is the same as 85 vs 91 octane. Prepare for fierce opposition from the masses.:deadhorse:
Factory ecu design and compression ratios play a large role in this, and I do think you're making an assumption. You are saying the factory ecu will advance endlessly to find knock. I doubt this very much. You're going to reach the limits of your camshafts, ecu, and engine design very quickly.
If what you say were true, everyone would run 91 octane. but realistically, most engines just don't have the capacity to "utilize" higher octane fuels.
I have found myself on your side of the fence in this theory. However, it turns out every engine is different, and so some logic must be followed. If your engine knocks, move to higher octane. If no knock.......:shrug:
Now if you had the ability to advance the timing yourself, that would be something.
I'd love for someone running E85 to chime in. If I could buy E85 in my town, I'd gladly do some experiments.
The MAP-ECU2 does retard and advance timing just fine.
Remember that the ignition timing on these trucks is DYNAMIC and it is always self tuning and adjusting the timing to the knock threshold hundreds of times a second.
Also remember you have taken a normally aspirated engine and have converted it to forced induction. When you jam more air into the cylinder you will lower the knock threshold so it will now be lower than stock.
If your ECU has pushed the timing out to the knock threshold and you have added 5 degrees of timing advance, YOU HAVE NOT ALTERED THE KNOCK THRESHOLD. The ECU will just pull out 5 degrees of timing.
Just because you made 271 HP and add a few degrees of timing with the MAP-ECU2 and make the same 271 HP does not mean it has not advanced the timing. If the ECU is already at the knock threshold it will just take out what you put in.
Now thing will get very dangerous. The ECU only has a LIMITED ability to retard timing to supress knock. Again, remember you took a normally aspirated engine and have converted it to forced induction. The ECU is not calibrated for a forced induction engine.
If you keep jacking in timing and the ECU keep pulling it out you will fast reach the point where the ECU cannot pull out any more and then if it knocks the ECU can no longer protect the engine and the engine will pop.
I know this is a hard concept to understand for some reason, but even very smart people sometimes needs a visual demonstration.
Peter, the owner of PMR the makers of MAP-ECU came to the US to visit with me. During this time we went out and tuned a truck together. It was a Taco with an STS system on it.
He told me to jack in some timing. I told him it will not do anything in boost. So, to show him, we did a power run and monitored the ignition advance on the scan tool. It was say 18* at WOT and full RPM. I jacked in 5* of advance and did another run. Now the timing on the scan tool dropped back to 13* of advance. The engine was at the knock threshold, something we cannot change and the ECU took out what we put in. The end result was no power change and we reduced the ECUs control authority to retard timing if needed to protect the engine.
This is all explained in the version of the U-Tune Guide I wrote for the AIC units.
The best approach here is to do a lot of data collection on your engine before you go strapping a turbo or supercharger to it. One of the many things you will want to know is what the ignition advance is at WOT and full RPM. Normally this is somewhere around 18-20* depending on engine and conditions.
Now you bolt up your forced induction system. After you get your fuel dialed in and you think your tune is straight, do a power run at WOT and see what the ignition advance is at full RPM. Lets say the boost has knocked your knock threshold down to 13*. The ECU has used up 5 degrees of its retard capability. How much authority does it have to retard timing? That is like asking how many licks does it take to get to the center of a tootsie pop. Know one really knows on most of these Toyota ECUs.
What if it can only retard 6* and you have used up 5 of it? Get the engine a little hot on a hot day and maybe the gas you got is not the greatest and the knock threshold drops. The ECU now needs 8* of retard to protect the engine. It needs 2 more than it has the ability to. Now you are driving around with knock and the internal engine parts are superheating because of all that energy that is going into the internal parts. You will quickly get things hot enough to start detonation and you just popped your engine.
So, what I like to do is to restore much of that retard authority as practical so the ECU can retard timing as needed. I will add retard in boost until I see the ignition advance move forward to where it was on the stock engine. In this example I have added 5* of retard and the scan tool is reporting the same 18* advance as it had stock and you have restored the ECU's control authority to retard timing in response to knock to protect the engine.
It is also important that you do not add to much retard. If you drop it to far you will loose power and send a lot of heat down the exhaust and over heat the cats. You can also induce knock with to much retard, but that is a more advanced lesson...
Yes, on some engines, the ECU programming is overly conservative. You maybe able to add some advance in vacuum where the ECU is not advancing enough to get to the knock threshold, but be very careful.
The MAP-ECU2 does retard and advance ignition timing. You just have to understand more of what is going on. You also have to never forget that ignition timing is dynamic and always self adjusting in an effort to get it to and keep it at the knock threshold.
Gadget
___________
This is all I was saying. If you fill up on e85, you will increase the knock threshold I agree. But that doesn't mean the engine/ecu is capable of putting it all to the ground smoothly.
E85 is a hot topic right now, someone needs to try it out and post up!
If you fill up with e85 (without new injectors and tune) you will definitely have knock (if it runs at all) since it will be way too lean (i.e. don't do it!) The ecu will have a maximum timing value based on the type of gas recommended (though it may push it to 93 octane settings then backoff if knock is detected, but I doubt it). It won't just increase until it detects knock and back off. Detonation is considered an abnormal condition, not a normal input parameter used to set timing.
To use e85, and get any benefit from it, you have to up the fuel system capacity by at least 50% and retune the ecm, including the timing and fuel tables. As I noted earlier, e85 tuning is tricky and you need an a/f gauge (wideband O2 sensor) and a dyno (to get the most out of it) and learn a lot about efi theory or take it to a tuner who knows e85.
E85 tuning is not tricky, its just like tuning any other fuel. True you would need an wideband o2 too tune but thats true on any fuel. I have tuned e85 cars for many years and its easy since it never wants too knock even when running really lean!!
