running my exhaust out to the side
DMC91187
Anybody have any tips/steps they used to do this? & did it help get rid of thee infamous rotten egg smell?
sawzall the canister off.
heat to bend and re-route or buy a 90 degree exhaust tip/elbow.
searching yields that yes, it helps. especially when the rear window is down.
It helps but doesn't eliminate the stink. I had a muffler shop do mine for a grand total of $30.
Dude, you can't heat and bend a 2.5" exhaust pipe 90 deg......
Muffler shop can do a tailpipe. Also magnaflow cat back is side exit. Rotten egg smell is your cats- different problem.
I had a muffler shop do this and add a chrome tip for like $60. Like the others have said, it reduces the smell but if you drop the hammer with the rear window open you can still smell it, not overwhelming like before but its still there. The second benefit of doing this mod is that it increases you departure angle off of obstacles; I had hit the tip of the straight-out-the-back factory exhaust numerous times offroading. Not so anymore!
whoops, sorry. didn't mean you could bend it 90 degress completely. i got mine out to about 30 degrees and added a turndown tip that i angled slightly down and out, that sufficed for me. its out from under and also to the side.
yes it may be a little pinched at the turning point where the resonator used to be, but it can't be impeding that much air flow. just a temporary deal until i can get to my house back at school where my welding stuff is and get a real elbow on there.
party on wayne.
youngrk
