Russian Volonter's SLR '00 Build Thread
Volonter
Greetings from Russian Federation, Moscow!
It's my SLR("Samiy Lutchiy Ranner", in English - "the best Runner")
3rd Gen Limited '00(not California Spec)
Shortly about it:
Multi-mode,
3,5" Front Suspension Lift Bilstein 5100/Ironman TOY055B
4" Rear Suspension Lift TLC80/OME 2861
2,5" bodylift
Eaton Truetrac Front Locker
OEM Rear E-Locker
Front 5,29 Yukon Gears
Rear 5,29 V6 Trail-Creeper Super Finish Gears,
315/75R16 Mickey Thompson MTZ
China NoName Snorkel
Custom Front Kingone TDS winch (17 meter per minute, 15000lbs) with Synthetic Rope 13mm
34cm under front armor
My spec list is long. It's takes a time to translate in english. But I can show it :)
If someone can read in Russian;)
If I wrote here anything, that means - "I had installed the new original Toyota part"
Engine:
— Spark plug gaskets, valve covers OEM
— Timing Belt, Tensioners OEM
— Generator Belt, Power Steering Belt, Air Conditioner Belt OEM
— Full Flushing and Cleaning oil system with oil pan disassembling
— Ignition wires OEM
— Ignition coils OEM
— Denso spark plugs K16TR-11 OEM
— Throttle sensor OEM
— MAF sensor OEM
— Both coolant temperature sensors OEM
— Oil cooler washing with gasket and valve replacing
— Oil Filter Nitto 4TP-122
— Semi-synthetic oil Petro-Canada "Supreme 5W-30" MOSP53C16
Fuel system:
— Fuel pump AEM 50-1000 320L/H
— Fuel pressure valve OEM
— Fuel filter(on the bottom of chasis) MAHLE KL 522
— Tank fuel filter OEM
Intake system:
— LLDPE China NoName Snorkel
— Custom Sealing in the filter box
— Air filter Alco MD-9652
— ISR mod 2:
- Silicone pipe 45grad 70-76mm Atomic er45-76-70 BLUE
- Silicone pipe 45grad 76mm Atomic e45-76 BLUE
- Power clamp 2.75 "(73-81mm)
- Power clamps 3 "(79-87mm)
- Aluminum pipe 3"
- Aluminum fitting(welded on pipe) 16mm
Exhaust system:
— Catalytic converter removed
— Magnaflow silencer (4 "x 9", length with flanges 20 ", barrel 14", stainless steel)
— Oxygen sensor OEM
— Custom Rear Oxygen sensor simulator AIS Auto
Система охлаждения и кондиционирование:
— Промывка системы охлаждения Fantа'ой (вливайся) :)
— Сварной алюминиевый радиатор увеличенного объёма(+3л) Tongshi(Китай)
— Патрубки ОЖ (идущие к блоку двигателя) OEM
— Помпа Aisin WPT-100
— Дополнительная электрическая помпа 1050 л/ч на обратку печки Bosch 0 392 023 004
— Шланги на доп. помпу Gates 3230-12171
— Кран печки OEM
— Промывка масляного радиатора с заменой прокладок и клапана
— Термостат OEM
— Радиатор печки OEM
— Сервопривод заслонки смешения воздуха OEM б/у
— Промывка радиатора кондиционера со снятием
— Блок управления кондиционером OEM
— ОЖ Toyota Long Life Coolant 08889-80014
Рулевое управление:
— Нижние сайлент-блоки с болтами — эксцентриками OEM
— Кастор выкручен до 2 градусов
— Рулевая рейка SAT ST-44250-60022
— Рулевые наконечники OEM
— Рулевой вал OEM
— Рулевой карданчик OEM
— Силуминовые втулки в рулевом заменены на болты
— Новые втулки и муфта OEM
— ГУР OEM
— Пыльник ГУРа от Scion xB 44399-52010 OEM
— Радиатор рабочей жидкости ГУР'а Tranny Cooler 4TC 22-13 без "спирали турбулентности"
— Усиленные шланги на радиатор ГУР Gates 3225-10014
— Рабочая жидкость OEM Dexron III 08886-80506
Трансмиссия:
— АКПП Aisin А340F (30-40LE) усиленная Serg4x4
— Сальники АКПП OEM
— Восстановленный ГТ 5VZ-FE без частичной блокировки 32000-35150
— Отдельный мозг АКПП Spitronics Neptune
— Доп. радиатор на АКПП Mishimoto MMTC-TF-1275
— Усиленные шланги на радиатор АКПП Gates 3225-10014
— Термостат на АКПП TRU-COOL
— Idemitsu ATF TYPE TLS-LV 10114042B
— Раздаточная коробка Multi-Mode
— Масло синтетическое Castrol Syntrax Longlife 75W-90 GL-5 21687
— Крестовины карданов OEM
— Отшприцованные карданы (каждые 10 000км)
Передний мост — 7,5" редуктор, независимая подвеска:
— Дроп боксы 1" на передний мост Total Chaos 96200
— Редуктор с червячным самоблокирующимся дифференциалом 88% Detroit TrueTrac TT911A644
— ГП 5.29 Yukon Gear T7.5R-529R
— Все подшипники, сальники и прокладки редуктора OEM
— ШРУСы OEM б/у
— Пыльники ШРУСов, хомуты, смазка ОЕM
— Масло минеральное Castrol Axle EPX 80W-90 GL-5 14FFAD
Задний мост — 8" редуктор V6, зависимая подвеска:
— Дифференциал с принудительной 100% блокировкой с электрическим приводом
— ГП 5.29 V6 Trail-Creeper Super Finish 301452-1
— Мост от 90 Прадо 2001 LSD б/у
— Чулок адаптирован под родной электролок (PCT)
— Blue Wire mod. Подключение блокировки отключено от положения раздатки, отключен ограничитель скорости 8 км/ч.
Подвеска:
Перед:
— Аммортизаторы Bilstein 5100 от Tundra I 24-188265 (настройка 0,71,3")
— Пыльники на аммортизатор Rancho RS1927
— Пружины Ironman TOY055B от 120 Прадо
— Отбойники типа "Русский Тимбрен" на базе Газелевских 14-2912622
— Верхние и нижние шаровые опоры OEM
— Сайлент-блоки верхних и нижних рычагов OEM
— Ступичные подшипники OEM
— Cтойки стабилизаторов задние от 185ого 4Runner'a CTR CLT-13 + удлинители стоек стабов Japan Made
— Резинки стабов OEM
— Реальный лифт подвески — 3,5"
Зад:
— Аммортизаторы ОЕМ от 80ки 48531-69535(48531-69540)
— Пружины OME 2861 от 80ки б/у
— Задний дропбокс для панары (made by AZIAT)
— Задние отбойники моста удлинённые "Русский Тимбрен" на базе Газелевских 14-2912622
— Cтойки стабилизаторов задние от 130ого 4Runner'a CTR CLT-30
— Лифт в разгруженном состоянии — 4,5", в загрузке — 3,2"
Тормозная система:
— Промыт бачок ГТЦ
— Вакуумный усилитель от TLC Prado 5VZ OEM б/у
— Прокачка контуров
— Тормозная жидкость Toyota DOT 5.1 08823-80004
Перед:
— Суппорта 47730-35110(правый) и 47750-35110(левый) под 15" колёсные диски от Hilux Surf RZN185W-GKPXK,
— Переборка суппортов OEM 04479-35021 под 15" суппорта
— Тормозные диски ОЕМ 43512-35280 297мм под 15" суппорта,
— Колодки NiBK PN-1387
— Армированные тормозные магистрали (+3" длины) Goodridge
Зад:
— Дисковые тормоза Прадо 90
— Тормозные диски Brembo 09.A334.11
— Колодки NiBK PN-1243
— Армированный тормозной шланг на мост (+4" длины) Goodridge
— Армированные тормозные шланги на суппорт Goodridge
Электрика:
— Перенос поворотников в боковые габариты
— Усиленная масса
— Новая силовая проводка 1х50 ПуГВ: стартер-генератор-аккумулятор
— Кастомные медные клеммы под обжимной наконечник Sound-Overdoze
— Стартер 28100-62030 1,8кВт ребилд на оригинальных з/ч
— Генератор 190А/ч от Nationsstarteralternator
— Аккумулятор ENEUS Perfect 125D31L 105А/ч 850А
Свет:
— Хрустальные фары ОЕМ от Surf 185: 81150-35310 и 81110-35330
— Би-Модули — Hella 4 "INTEMO" SuperNEW 3" (Германия)
— Блоки розжига — MTF Light D2-A2030
— Лампы — Philips D2S 85122 YX 3000К (жёлтый свет)
— Бленды с диодными ДХО Porsche
— Электрокорректор фар
— Автокорректор фар Hella 8XX 010 315-001
— Водозащищённые сапуны на фары Nitto Denko 92163 39000QQK
— Хрустальные габариты ОЕМ от Surf 185
— Поворотники перенесены в габариты, лампы OSRAM
— 2 x Light Force XGT 240мм 100W(галоген) на бампере
— Светофильтры на XGT 240мм лимонно-жёлтые, комбо
— 2 х Диодные фары заполняющего(Scene) света Aurora ALO-2-E12T 40W на задний ход
Кузовные работы:
— Покраска рамки лобового стекла+ установка нового стекла+ заваривание пола и покраска
— Замена всех 10 подушек кузова+болты+втулки+гайки ОЕМ
— Лифт кузова 65мм чёрными капролоновыми проставками (около 2,5") (ширина проставок: 65мм — спереди, 77,5мм — остальные) + удлинение рулевой вваркой трубы + изменение геометрии ручки раздатки + новые топливопроводы до бака шлангами МБС.
Подготовка к бездорожью:
— Защита картера сталь 3мм Sheriff 24.0867
— Широкие силовые пороги от МШУ (noroad.ru)
— Сапуны мостов, АКПП, раздатки выведены под капот и в вентиляцию бензобака соответственно.
— Квадрат с шаклом 3/4 в фаркоп
Лебёдки:
Передняя:
— Лебёдка KingOne TDS (была TDS 6,5) 173:1 V=17м/мин.
— Мотор лебёдки WARN XP 6л.c., якорь 84мм.
— Синтетический трос China 13мм в оплётке
— Механический ключ на массу лебёдки Hella 6EK 002 843-121 на 500А
— Управление смоткой и размоткой кнопкой из салона
— Силовая проводка ПуГВ 1х50кв. мм.
— Перенос блока соленоидов лебёдки под капот
— Сетка-держатель троса на бампер Hand-made
Задняя:
— Лебёдка KingOne KDS12 (254:1), мотор(не якорь) 180мм 6л.с.
— Синтетический трос OTS Dextron plus 10mm
Радиосвязь:
— Радиостанция СВ Megajet MJ-850 в 1DIN рамку доработанная Кабаном(Ci-bi.ru)
— Антенна Optim 2001 (2 метра) доработанная Кабаном (Ci-bi.ru)
— Кронштейн антенны РСТ
— Переносная УКВ-радиостанция Baofeng UV-5R
Подготовка к экспедиции:
— Бокс на крышу LUX600 160*92*40 см 440 литров
Салон:
— Сидение Recaro от 130ого Hilux Surf
— Спальник от Lapocruiser
— Для удобства посадки на задний ряд добавлены ручки в верхнем правом и левом углах задних дверей от Прадо 90 OEM
— Руль пластиковый в цвет салона от Прадо 90
— Тумблеры доп. оборудования Carling Technologies
— "Крутилка" задней блокировки оригинал Прадо 90
— Коврики салона резиновые Avvk/Rezkon A.004.87.S
Колёса:
— Проставки на передние ступицы Starleks 5мм
— Удлинённые колёсные шпильки OEM 90942-02079
— Летние 315/75R16 Mickey Thompson MTZ — Диски Slik L79 16х8 ЕТ=-15
Some video's "SLR in action"))
https://www.youtube.com/watch?v=2Lx2WNfu9dM
https://www.youtube.com/watch?v=6bfMAX9kzic
Google Translate to the rescue!
Engine:
- cylinder head gaskets, spark plug wells, valve OEM cover
- timing, tensioners, OEM rollers
- Drive belts OEM
- Raskoksovanie, complete flushing and cleaning the oil system with pallet lifting
- OEM wires
- OEM ignition coils
- Nickel two-electrode spark plugs Denso K16TR-11 OEM
- OEM DPDZ - OEM
DMR
- Both coolant temperature sensors OEM
- Oil cooler washer (replacement) with gasket and valve replacement
- Oil filter Nitto 4TP-122
- Synthetic oil semi-synthetic Petro-Canada "Supreme 5W-30" MOSP53C16
Fuel system:
- Fuel pump AEM 50-1000 320 l / h
- New fuel regulator (pressure regulator in the rack) OEM
- Fuel filter for fine cleaning MAHLE KL 522
- Fuel filter for rough cleaning OEM
Intake system:
- Snorkel LLDPE china
- Sealing insert in the box filter
- Air filter Alco MD-9652
- ISR mod 2:
- Silicone 45gr 70-76mm Atomic er45-76-70 BLUE
- Silicone 45gr 76mm Atomic e45-76 BLUE
- Aluminum pipe 76mm
- Aluminum fitting 16mm
Exhaust system:
- The catalyst is cut and the flame arrestor is inserted
- Muffler Magnaflow (4 "x 9", length with flanges 20 ", barrel 14", stainless steel)
- Lambda probe OEM
- Electronic blending for 2nd lambda AIS-AUTO
Cooling and air conditioning system:
- Flushing of the Fanta Sign up)
- Welded aluminum radiator larger volume (+ 3l) Tongshi (China)
- Nozzles coolant (coming to the engine block) OEM
- pump Aisin WPT-100
- General electric pump 1050 l / h on the stove obratku Bosch 0392023004
- Hoses on additional. Pump Gates 3230-12171
- OEM Oven Crane
- Oil Heatsink Washer with Gaskets and Valve Replacement
- OEM Thermostat
- OEM Furnace Radiator - OEM Air Mix Shutter Servomotor
used
- Radiator cleaning of the air conditioner with removal
- Air conditioning control unit OEM
- Coolant Toyota Long Life Coolant 08889-80014
Steering:
- Lower silent blocks with eccentric screws OEM
- Castor screwed up to 2 degrees - Steering
Rack SAT ST-44250-60022
- Steering OEM tips
- Steering shaft OEM
- Steering wheel OEM
- Silumin bushings in the steering are replaced with bolts
- New bushings and clutch OEM
- GUR OEM
- Gear Shaper of Scion xB 44399-52010 OEM
- Radiator of hydraulic fluid GUR'a Tranny Cooler 4TC 22-13 without a "spiral of turbulence"
- Reinforced hoses for the GUR radiator Gates 3225-10014
- Working fluid OEM Dexron III 08886-80506
Transmission:
- Automatic transmission Aisin А340F (30-40LE) reinforced Serg4x4
- Oil seal OEM
- Recycled ГТ 5VZ-FE without partial blocking 32000-35150
- Separate brain Automatic transmission Spitronics Neptune
- Mishimoto MMTC-TF-1275
- Reinforced hoses for radiator Gates 3225-10014
- Thermostat for automatic transmission TRU-COOL
- Idemitsu ATF TYPE TLS-LV 10114042B
- Transfer case Multi-Mode
- Synthetic oil Castrol Syntrax Longlife 75W-90 GL -5 21687
- Crossings of cardans OEM
- Exposed cardans (every 10 000 km)
Front axle - 7.5 "reducer, independent suspension:
- Drop box 1 "onto the front axle Total Chaos 96200
- Reducer with a worm self-locking differential 88% Detroit TrueTrac TT911A644
- GP 5.29 Yukon Gear T7.5R-529R
- All bearings, seals and gaskets OEM
- OEM SHRUSS
- Anthers CV joints , clamps, lubrication OEM
- Mineral oil Castrol Axle EPX 80W-90 GL-5 14FFAD
Rear axle - 8 "reducer V6, dependent suspension:
- Differential with forced 100% locking with electric drive
- GP 5.29 V6 Trail-Creeper Super Finish 301452- 1
- All bearings, seals and gaskets of the reducer OEM
- The bridge from 90 Prado 2001 LSD used
- The stocking is adapted for the native electric owl (PCT)
- Blue Wire mod. The interlocking is disconnected from the dispensing position, the speed limiter is disconnected at 8 km / h.
Suspension:
Before:
- Shock absorbers Bilstein 5100 from Tundra I 24-188265 (adjustment 0,71,3 ")
- Anthers for the amortization Rancho RS1927
- Springs Ironman TOY055B from 120 Prado
- Boots of the "Russian Timbren" type based on Gazellevsky 14-2912622
- Top and bottom ball bearings OEM
- Silent blocks of upper and lower levers OEM
- Wheel bearings OEM
- Stabilizer bars rear from 185th 4Runner'a CTR CLT-13 + Made
- Rubber Stabs OEM
- Real Suspension Lift - 3.5 "
Зад:
- Shock absorbers ОЕМ от 80ки 48531-69535 (48531-69540)
- Springs OME 2861 от 80ки second hand
- Rear dropbox for panary (made by AZIAT)
- Rear bumpers of the bridge lengthened "Russian Timbren" on the basis of Gazellevsky 14-2912622
- Stabilizers rear from 130th 4Runner'a CTR CLT-30
- Rubber stabs OEM
- Elevator in unloaded state - 4,5 ", in loading - 3,2"
Brake system:
- Washed tank GTZ
- Vacuum amplifier from TLC Prado 5VZ OEM б / u
- Prorolling contours
- Brake fluid Toyota DOT 5.1 08823-80004
Before:
- Caliper 47730-35110 (right) and 47750-35110 (left) under the 15 "wheels from Hilux Surf RZN185W-GKPXK,
Reassembling of calipers OEM 04479-35021 under 15 "calipers
- Brake discs OEM 43512-35280 297mm under the 15" caliper,
- Pads NiBK PN-1387
- Reinforced brake lines (+3 "length) Goodridge
Back:
- Disc brakes Prado 90
- Bulkhead support
wheels OEM - Brembo brake discs 09.A334.11
- NiBK brake pads PN-1243
- Reinforced brake hose for the bridge (+4 "length) Goodridge
- Reinforced brake hoses on the Goodridge caliper
Electrician:
- Side-to-side shifts
- Reinforced mass
- New power wiring 1х50 ПГВ: starter-generator-accumulator
- Custom copper terminals for roasting me the tip of Sound-Overdoze
- Starter 28100-62030 1,8kW rebuild on the original w / h
- Generator 190A / h from Nationsstarteralternator
- Battery ENEUS Perfect 125D31L 105A / h 850A
Light:
- Crystal headlights OEM from Surf 185: 81150-35310 and 81110-35330
- Bi- Modules - Hella 4 "INTEMO" SuperNEW 3 "(Germany)
- Units of ignition - MTF Light D2-A2030
- Lamps - Philips D2S 85122 YX 3000K (yellow light)
- Hoods with diode DRLs Porsche
- Headlamp corrector
- Auto-corrector Hella 8XX 010 315 -001
- Waterproof breathers for the headlights Nitto Denko 92163 39000QQK
- Crystal dimensions of the OEM from Surf 185
- The rotors are moved to dimensions, the lamps OSRAM
- 2 x Light Force XGT 240mm 100W (halogen) on the bumper
- Filters on XGT 240mm lemon yellow, combo
- 2 x Diode headlights filling Scene light Aurora ALO-2-E12T 40W for reverse gear
Bodywork:
- Painting of windshield frame + installation of new glass + brewing of floor and painting
- Replacement of all 10 body cushions + bolts + bushings + nuts OEM
- Body lift 65mm with black caprolon spacers (approx. 2.5 ") (width of spacers: 65mm in front, 77.5mm in others) + extension of steering tube welding + change of handle geometry + new fuel tank hoses to MBS.
Preparing for the road:
- crankcase protection hoist 3mm 24.0867 Sheriff
- Wide power thresholds of the LNA (noroad.ru)
- Sappoons of bridges, automatic transmission, distributions are led out under the hood and into the ventilation of the gas tank, respectively.
- Square with a 3/4 trolley to the towbar.
Winches:
Front:
- Winches KingOne TDS (was TDS 6,5) 173: 1 V = 17m / min.
- Wincher winch WARN XP 6l.c., anchor 84mm.
- Synthetic cable China 13mm in braid
- Mechanical key to the weight of the winder Hella 6EK 002 843-121 for 500A
- Control of the look and unwinding by the button from the cabin
- Power wiring PGW 1h50kv. mm.
- Transfer of the winch solenoid block under the hood
- Grid-holder of the cable on the bumper Hand-made
Rear:
- Winches KingOne KDS12 (254: 1), motor (not anchor) 180mm 6hp.
- Synthetic OTS cable Dextron plus 10mm
Radio communication:
- Radio station Megajet MJ-850 in 1DIN frame modified by Kaban (Ci-bi.ru)
- Aerial Optim 2001 (2 meters) modified by Kaban (Ci-bi.ru)
- Antenna of PCT antenna
- Portable VHF radio Baofeng UV-5R
Preparation to the expedition:
- Boxing on the roof LUX600 160 * 92 * 40 cm 440 liters
Salon:
- Recaro seat from the 130th Hilux Surf
- Sleeping bag from Lapocruiser
- For easy planting on the back row, handles are added in the top right and left corners of the rear doors from the Prado 90 OEM
- The steering wheel is plastic in the color of the salon from the Prado 90
- Toggle switches. equipment Carling Technologies
- "Twirl" rear lock original Prado 90
- Rubber interior mats Avvk / Rezkon A.004.87.S
Wheels:
- Spacers on the front hubs Starleks 5mm
- Extended wheel studs OEM 90942-02079
- Summer 315 / 75R16 Mickey Thompson MTZ - Slik L79 16x8 ET = -15
