Rust belt 3rd member back plates
Yes I noticed that it supposed to fit. I just curious if it actually does.
Mostly the tocuma always fit any kind of replacement cover because they dont have a lateral control arm really close to the differential. It does look like it will fit. I just curious if anyone has done it. :)
Sent from my SM-J337V using Tapatalk
I guess it fairly safe to say that nobody's done this yet. That's ok. Eventually I do the axle housing I saved with a pin hole in it and replace the back plate. :)
Can't wait till someone tries to put one on with a wire feed. I'd rather (and did) have the Barnes cover. 20 dollars more gets you a larger cover that's thicker too.
You could try it and if it doesn’t provide the clearance you need you have a good excuse to put leaf springs in the back and an 80 series axle in the front
Clear the lateral control arm?.. I have seen a pile that won't..
Lol.. I dont miss the live axle front ends as a dont go wheeling in them..:)
Cleared just fine.
Great to know. As I heard stories of people not checking clearances and it hit the lateral control arm smashing it into the 3rd member. I believe if I do one I use the one you have. :)
matisgugle
