FinsNThings
$6,000
Not interested in trades
Clean title in hand
Stock 1999 Toyota 4Runner Limited with 285k miles.
The 1999 and 2000 Limited were the only model years that came with the standard four-wheel drive (4Hi/4Lo), and center and rear locking differentials.
Majority of the miles are freeway.
Has pull-out cargo area cover.
Everything works on the vehicle.
The factory automatic antenna was replaced with a fixed wire antenna.
The drivers side mirror has a crack.
Minor surface rust on frame.
Recent maintenance done:
16 March 2022:
Replaced right rear wheel bearing
Cleaned & serviced brake components & adjusted park brake
Replaced Valve Cover Gasket
Installed new camshaft rear discs & resealed half-moons
Fuel Injector Clean & Flow charted
Replaced Fuel Filter
Replaced Outer Drive Belts
Cleaned MAF Sensor
Replaced Front Sway Bar Bushings
29 January 2025:
Transmission pan replaced
Drive-train service (differential and transfer case)
5 February 2025:
Radiator/Coolant flush
2 July 2025:
Replaced drivers bottom seat cushion and cover.
Clean title in hand
16 March 2022:
Cleaned MAF Sensor
29 January 2025:
5 February 2025:
2 July 2025:
