Rust under my 4Runner... what can I spray it with?
nick168
What spray is available to spray over rust without sanding to kill and contain rust.. I ask because I can’t reach areas.. car is from NY I am in FL now so I shouldn’t come across salt again.. thanks guys
POR-15 or chassis saver I have heard work well. I did por-15 on a few small spots I had. It goes right over rust, I think you just have to make sure it’s mostly clean first.
There's multiple threads on here about rust prevention. I think they all mention what was used. Here's a couple to get you started:
Simple Frame Rust Repair/Prevention. - Toyota 4Runner Forum - Largest 4Runner Forum
New owner, need advice regarding rust and maintenance - Toyota 4Runner Forum - Largest 4Runner Forum
I’m in MA, so I’ve had to deal with this on mine obviously. I opted to sandblast the frame, then prime and paint it black. I probably should’ve used POR-15 in place of the primer, but it didn’t fit my timeframe for when I was able to do the blasting, so I just used red oxide primer. Keep in mind, that just spraying any type of coating will not entirely solve the problem because a lot of the rust comes through from INSIDE the frame! Eastwood makes an internal frame coating that many have used on here with good success, but haven’t done mine yet. I do plan to try it in the spring/summer though because my truck is in awesome condition at 130k miles, and I plan to keep it a LONG time, so I don’t hate to have the rust cancer end it’s life early!
There is absolutely no product made you can spray up into "I cant reach areas" and stop rust. To stop rust, you must be able to have access to it and properly prep the surface. POR 15 is an amazing product that works but its success depends on the surface prep. Not properly prepped and it will be flaking off in a year.
If it is just a thin layer of surface rust. A wire brush followed by Rustoleum rust primer will work. It there is pitting, bubble, rot, you have to go por 15. More than likely it will require body off the frame.
That internal frame coating stuff is snake oil. You are wasting time and money. There is no magic stuff you can spray on pitting rust and get it to stop.
If the rust is due to road brine from up north. Unfortunately, if it saturates the frame and allowed to sit, salt actually embeds itself in the metal and continues to eat away. A good hosing after going through the stuff would have stopped it.
I will never buy a vehicle from up north of VA/
Amazing how well this aviation product works. I use it on battery terminals too.
CorrosionX® Aviation takes corrosion control to a whole new level! Featuring the latest advances in Polar Bonding and Fluid Thin Film Coating (FTFC) technologies, CorrosionX Aviation is specially formulated to displace moisture, stop corrosion instantly and provide long-lasting protection. Made entirely in the USA, CorrosionX Aviation is qualified under MIL-PRF-81309 Rev. G Type II (replaces and supersedes MIL-PRF-81309F and MIL-C-81309E) for corrosion prevention and control on airframes — and now, general purpose use as well. Used extensively by the U.S. military as well as NATO forces, all CorrosionX products and application equipment have been assigned National Stock Numbers (NSN) by the General Services Agency (GSA) and are available for procurement through the Defense Logistics Agency (DLA). Corrosion X is the only product available to the public that meets the US Navy's tough new corrosion prevention and control performance requirement ( MIL-PRF-81309G ).
Kills & Prevents Corrosion
Long-Lasting Polar Bonding Technology
Displaces Moisture
Penetrates & Lubricates
Effective On All Metals
Contains No Waxes Or Silicones
Aviation Applications
Apply to airframe interiors, battery terminals, hinges, cables, wheel hubs, rotor heads and trim drum actuators. Ideal for exhaust and turbocharger components. It may also be applied to electrical and avionic components such as micro switches, cannon plugs, antenna bases, circuit breakers and buss bars.
