Koz
Well yesterday I had to take my rear plate off my BABY! It turns out the frame was bent and Toyota frames cannot be repaired, only replaced. Needless to say, the repair cost was too close to the current value so it was declared "TOTALED".
There is good news and bad news! The resale value of the 4Runner is amazing. After almost 6 years it is worth more than half the purchase price. Now the bad news. My 4Runner can NOT be replaced with a new 4Runner. Two big reasons; I need a tow rating over 5K lbs (No more V8) and the auto leveling air suspension is no longer available. I also stopped at a Toyota Stealer and finally took a good look at the new redesigned 4Runner. Please don't take this the wrong way but even if there was still a V8 and air suspension available, I don't think I would get the new 4Runner. I think the exterior could grow on me but the interior is horrible! The design and materials are nowhere near as nice as the 4th gen (WTF). What a disappointment!
I also stopped at a Lexus Stealer to take a look at the new GX460. Again, good news and bad news. The GX is absolutely amazing. Everything about it is so sweet. It has to be the quietest vehicle I have ever been in (Cars included). I'm talking DEAD silence. Talk about a smooth/solid ride. You can’t imagine that a vehicle that was primarily designed for off-roading could be so amazing on the street and could have so much luxury (Ride and gadgets). I can’t believe all the special features for off-roading alone. I won’t bore you with all the luxury features, I’ll just mention some of the off-roading and suspension features.
2 Speed transfer case (2.56:1) with a 3.9:1 final gear ratio
6 speed trans
Locking Torsen center diff
Hill-start/downhill assist
Crawl control (With 3 settings from 1 to 3.7 mph)
KDSS (Amazing)
AVS – Adaptive Variable Suspension - Sensors monitor wheel speed, engine rpm, steering-wheel movement, brake application and vertical body motion to determine the ideal damping rate for each shock absorber. The driver can also select the ride firmness with the press of a button. (3 Settings – sport/normal/comfort)
Electronically modulated auto leveling air suspension (3 Settings)
Wide view front/side/rear monitor system (cameras that show split screen on the 8” nav display while moving)
Power folding side mirrors
The bad news - $60,000
Koz
6 speed trans
KDSS (Amazing)
Koz
