Safari bar and PIAAs
ironadrenaline
ok two things.
first i got the westin safari bar in the mail finally and i tried installing it. only problem is that i couldnt get the bolts off from behind the bumper to install this damn thing. for anyone who installed it themselves, how did you get by that? i tried everything. theyre fused on.
and second, i remember reading in another thread that a member here installed his PIAAs so they come on with the high beams. if thats you, how do i do that? or am i better off just running the switch into the cabin?
ironadrenaline said:
ok two things.
I sprayed WD40 on them and used an air wrench on the bolts.
Just us a splice connector and tap into the high beam wires just behind the bulb connector.
thanks...
only problem is i dont have an air wrench.
and which wire do i tap with. there are 2 white with red spots and a black.
thanks...
If your going to working on your car in the future it is a good investment to safe your hands.
The white with the red spots. If you can't find a good ground for the aux lights you can connect that to the black.
Or get yourself a breaker bar to bust lose those bumper bolts. They're on super tight for a reason ;):
If you can't find a breaker bar, slip a hollow metal tube over the wrench. The longer the wrench the bigger the turning power.
i actually used an old lacrosse stick from a buddy of mine. cut it down to about 15 inches and it worked great. the lights look great and the bar is steady. thanks for all your help
