SAS up for grabs
Singtoe
I think is a good deal for one of you's.
NC4x4
'84 toyota 8" axle - 4.10. aussie locker. longfield 30 spline birfs and inners. longfield hub gears. arp knuckle studs. tg upper gusset. factory lower gusset. tg diff guard. fresh plugs. brake backing plate eliminators. tg rock ring felt protectors. tg knuckle ball gussets w/ shock mounts. less than 100 miles on complete rebuild w/ new seals, bearings, brake rotors, calipers, and pads. clean. good paint. no rust. $900
P1110817.jpg~original
P1110818.jpg~original
P1110819.jpg~original
Not a bad deal, that Aussie would be sweet up front :naughty:
Dous, aren't you 2wd? I'll have a Tcase up for sale soon real cheap. :naughty:
The tranny is shot but I could get you the wiring as well with the gear shifter...not sure if it can work with the 2wd tranny but I bet Singtoe does.
The V6 transmission will not bolt up to my 4 cylinder. I need to find a 4x4 2.7 Tacoma if I wanna do the swap and keep the 4banger. V8 might work though too :hungry:
Edit: Oh you are talking about bolting the transfer case up to my transmission, good question.
The mini truck axles are too narrow for a 3rd gen IMHO. a FJ80 axle would be a better fit. Still a good deal for a built mini truck axle though
If it was passenger side drop,i think it could work.
I didn't realize the narrowness of it though. DOUS is only running spider trax in the front though, so it might be ok for him.
our truck can only use driver side drop axle with our stock tc? thats what i thought, anyway d44 would be the way to go imo.
The D44 and toy gear ratios only agree up to 4.88... But I agree about the width on mini truck axles being too narrow. I would definitely go wider if I sas'd
Children of Bodom's tranny is off a v6 and he's got a 4banger. I think you need a different bellhousing to make it fit.
BillM777
