jacal
With respect to mounting the antenna, why is the rear of the suv the suggested location? If you had a gear box or roof mounted items wouldn't you risk blocking the signal? Also, does a layer of ice and/or snow degrade the signal? If so, I will need to keep it clean, which will help determine my location.
I have noticed, with the inclement winter weather, that sometimes the rear hatch "grinds" the ice and snow that accumulates along the top. I worry that a cable run thru that area might get damaged when space becomes filled in with ice/snow.
Could the ant just be mounted to the spoiler? I suppose some sort of adhesive could work there? That would be nice because the existing wiring could be followed, and maybe just a small hole drilled aboove the leds on the spoiler?
In some ways, mounting it up front might be a better solution.
Thoughts? feedback?
J
Thoughts? feedback?
J
